Author Topic: INFO: Sound deadening tips for the Mk3!  (Read 28547 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Sound deadening tips for the Mk3!
« Reply #20 on: 21 May 2009, 08:58 »
These guys keep it in stock as i've purchased it from them in the past for my previous mk2
http://stores.shop.ebay.co.uk/autotronics1234__W0QQ_armrsZ1
Offline B-chi
« Reply #21 on: 04 June 2009, 21:08 »
Just sound deadened both doors with 2.5mm stuff from a guy called loudboy on Talkaudio. It's fricking brilliant. About £22 a metre sq sheet. 1 sheet does the inner & outer skin of a front door. He also does a 4mm for £30 a sheet.
I've got a couple of pics
« Reply #22 on: 05 June 2009, 18:22 »
Ah cool, so 4 sq metres should be enough to do all 4 doors thougherly then. has it made a significant difference using the 2.5mm sheet, or do you think id be better off opting for the 4mm gear?
Offline B-chi
« Reply #23 on: 06 June 2009, 06:57 »
I normally can't tell the difference between things. Mp3 & cd quality for instance. But having these installed in my fiesta (no deadening) & installed in my golf, I've noticed the midbass is more prominent, & they are clearer at higher volumes.
From outside I can feel the door vibrate but can't hear any rattles. I'm running 150wrms a side ATM & they're doing well. Will see what happens when I've got my subs in off 1.5kwrms.
The reason I opted for the 2.5mm is the 4mm is 8kg per sheet. 4 sheets = 32kg.
Offline Andy-H
« Reply #24 on: 11 August 2009, 07:49 »
I have recently been having issues with a really noisy Powerflow exhaust. I bought some "SoundX" off the bay (20 square feet of it) and I've done the boot floor, boot sides, inside the boot lid and also Len's trick of under the rear seat.
Although I can still hear the exhaust, it isn't half as bad as it was  :wink: Big improvement and the entire coverage was only £30 delivered and weighed in at 7kg.
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline Nino
« Reply #25 on: 10 March 2010, 01:30 »
nice tip
VW Car history
Mk3 1.8 GL - Silver - 5 door
Mk4 1.8t - Silver - 3 door
Mk4 R32 - Black - 5 door
Mk5 GTi - Black - 5 door
Mk4 R32 - Deep Pearl Blue - 3 door
MK6 2.0 TDI - Graphite Blue - 5 door
MK7 GTD - Solid Black - 5 door
MK6 GTi Edition 35 - Candy White - 3 door
