Author Topic: 1.8T Nightmare (continued) - Please help  (Read 26941 times)
Offline ben1.8T
Re: 1.8T Nightmare (continued) - Please help
« Reply #40 on: 19 February 2009, 14:04 »
yep  :undecided:
Fooking hell that aint cheap.  :shocked:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline redevo1
  • golt gti 1.8t AGU
« Reply #41 on: 19 February 2009, 14:14 »
I had a simliar problem with an Evo turned out to be a loose conection into the ECU have a look at where the loom goes into the ECU? If conections loose it'll be a intermittent fault? :undecided:
God I've got a golf I'm getting old!Full Recaro leather with arse waming seats, the reason for buying a Golf!Spec: R tech remap:Eibach Fr+Rr ARB:Powerflex ARB bushes:Forge BOF DV:Silicone TIP:Induction kit:Jamex suspension:312mm big brake setup: EBC pads F+R:Vr6/g60 clutch:5mm-fr+15mm-rr spacers: Anni front & rear Valances & Anni rear roof spoiler: Silicone hose boost/Breather kit.
Offline rheady
« Reply #42 on: 19 February 2009, 14:34 »
F@@king hell thats steep. I'll call my local dealers and check again..
Offline rheady
« Reply #43 on: 19 February 2009, 21:24 »
Called VW and quoted £350 was gobsmacked at the cost
Offline sambo
« Reply #44 on: 19 February 2009, 21:59 »
Hi mate sorry to hear about the prob's.
Don't know much about the DBW set up, is there a pedal sensor that could be replaced?
How often does it do it?
Hope you get it sorted soon!
Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline Krispy
« Reply #45 on: 19 February 2009, 22:02 »
Sam
yes mate there is also a pedal sensor but i have changed that too..
People over at vwvortex reckon it might be my MAP sensor or im getting a fault code on vagcom about a faulty brake switch, they think it could be one of the two.
Also it happens everytime i drive it... very frustrating!
Offline sambo
« Reply #46 on: 19 February 2009, 22:20 »
can you not record some logs as previously said on vag com and take it for a drive until it does it?
Also would the lambda sensor cause it? I think i remember hearing lambda failure doesn't show up as a fault sometimes but if you check the reading via vag com it will be 0 or something like that?
A few stab's in the dark really, sorry can't be much more help  :nerd:
Sam
Sam
Offline monzablue16v
« Reply #47 on: 19 February 2009, 23:22 »
Take some logs and post them up dude, you can log to a csv file iirc :) log as much as you can and we may be able to see something :)
Offline Krispy
« Reply #48 on: 19 February 2009, 23:46 »
ill try mate, gonna have to find someone with vag-com though..
Offline Rhyso
« Reply #49 on: 20 February 2009, 08:01 »
PM Kalu over on ukmiv's - i think he's in London somewhere lol
he's a bit of a VAG COM guru  :nerd:
