What if I want to run the oil temp on the MFA to be water temp (which I think I've worked out -just swapped the oil temp wire to the water temp)
BUT, I want to wire up the VDO's to oil temp/pressure so i don't need the T piece.
It's an Areg 8v, so I replaced the front sensor with the twin sender, but it doesn't move/read at all. The 2 wires from the gauges go where???
Do I put the pressure gauge wire to the OE pressure gauge? What happens with the oil pressure buzzer?
