Author Topic: How To: Replace the thermostat  (Read 113855 times)
Offline Dave_IOW
Re: How To: Replace the thermostat
« Reply #10 on: 12 January 2010, 19:37 »
If is temp sender, its 5 min job and 20quid genuine part. Im useless under bonnet and i managed it which says alot.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Gozza
« Reply #11 on: 12 January 2010, 20:08 »
Thanks will have a look over the weekend and make sure not a loose connection or similar plus see what colour one I need and put it right. Hate not knowing the temp of my car, drove it for about 30 mins the other day and sat just off cold  :angry:
Offline Dave_IOW
« Reply #12 on: 12 January 2010, 20:18 »
not knowing when its up to temp so u can give it some does get annoying  :laugh:
Offline Gozza
« Reply #13 on: 12 January 2010, 20:26 »
funnily enough thats one of the reasons  :laugh:
I also noticed it took ages for the heaters to get warm.
Offline T_J_G
« Reply #14 on: 13 January 2010, 14:43 »
Sounds like a dodgy thermostat, to be honest though both are probably worth replacing!
Offline Gozza
« Reply #15 on: 13 January 2010, 19:34 »
I did think that too but this is easier to replace so may start with this. I had the water changed recently so thought it may of solved it just in case loose connection etc but seems to have made it worse :/
Offline TJJONESVDUB
  • Give me lip and il tattoo daihatsu to your head!
« Reply #16 on: 19 January 2010, 01:49 »
anybody near south wales fancy doing this for me i had one of my mate when i changed mine looks like his has failed now aswel lol ??? im now fed up of 30quid worth of v-power lasting 55 miles
Offline Mk1Macca
« Reply #17 on: 05 February 2010, 21:08 »
You used G12++ not water right?!
Offline Gozza
« Reply #18 on: 06 February 2010, 08:50 »
Was done by the garage and they used all the proper anti-freeze etc ;)
Offline TJJONESVDUB
« Reply #19 on: 08 February 2010, 09:54 »
IF your a dipstick like some of us and you snap your dipstick guide they are £3.49 from VW and they stock them. Good guide even if i did spend 9 long hours trying to get the bottom bolt undone on the thermostat to then find out its the temp sensor, which have now gone up to £32 < :sick:
