Author Topic: Changing rear axle bushes  (Read 33386 times)
Offline hutch6447
« on: 08 May 2009, 20:32 »
Is changing the rear bushes a decent job to do, if so has anyone get the step by step guide to completing job thanks ?
Offline Ridg
  • TDI - Soot Happens!
Re: Changing rear axle bushes
« Reply #1 on: 08 May 2009, 21:38 »
here's one i bookmarked earlier
http://forums.vwvortex.com/zerothread?id=1980960
I paid a local garage to do mine as they have special tools to pop the bushes in and out, eg not a hammer and g clamp like in the guide.
if you're replacing them, the Leon Cupra R bushes are the ones to go for.
Offline Steve_PD
« Reply #2 on: 08 May 2009, 22:31 »
Or the Fabia VRS for a quarter of the price  :wink:
Offline Ridg
« Reply #3 on: 09 May 2009, 00:07 »
hadn't heard of the vRS bushes being used in the MK4, so just checked ETKA and a quick read through http://uk-mkivs.net/forums/t/254751.aspx
and as I suspected different part numbers, but from the looks of it a very similar part, probably a slightly firmer rubber in the LCR given that the LCR is heavier than the vRS
standard MK4 bush;
1J0 501 541 C
vRS bush part number;
6Q0 501 541 E
LCR bush;
1ML 501 541
Offline jonnyturbo
« Reply #4 on: 09 May 2009, 20:25 »
NortheastGTI is your man to ask about rear beam bushes lol
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 09 May 2009, 23:28 »
mmmmmmmmm :rolleyes: :huh: yep i took mine into a local garage supplied the oem ones and got them fitted for £40 :afro:
2000 Mkiv GTi 1.8T AGU
Offline johnson6672
« Reply #6 on: 10 May 2009, 11:48 »
I got Vrs on mine, jobs not too bad too do just make sure you clamp your brake hoses!!!
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline sidney69
« Reply #7 on: 14 September 2009, 14:36 »
Chaps... I need to replace my rear axle bushes and have been told that the vRS will fit my vehicle on a number of forums. However, when I contacted AVS - vwspares, they stated that on my particular model, the rear axle bushes are 69mm ones and not the vRS type which are 72mm ones. Can anyone confirm whether the vRS ones will definitely fit or not... thanks
  • "1.8T AGU"
« Reply #8 on: 14 September 2009, 14:42 »
vRS bushes will fit  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 14 September 2009, 17:11 »
what year is your car mate?
