Author Topic: The 1.8T Air box/Induction thread  (Read 27958 times)
Offline navmk4gti
Re: The 1.8T Air box/Induction thread
« Reply #40 on: 12 June 2013, 19:52 »
I see you took out the intake pipes too dave. An plans on cold air feed or anything :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #41 on: 12 June 2013, 20:15 »
A quick convo via text to Nick today gave the info I need; the standard airbox gets restrictive around 230bhp so mine will be changing soon
Offline GunnerCP
« Reply #42 on: 12 June 2013, 21:07 »
What size reducer do you need for the s2k filter? From _ - _?
Thanks
Offline paultownsend
« Reply #43 on: 12 June 2013, 21:22 »
86-80
Go to JS Performance. Top service.
Offline GunnerCP
« Reply #44 on: 12 June 2013, 21:36 »
86-80
Thanks, Can't see that size on their site?
« Reply #45 on: 12 June 2013, 21:42 »
I just phoned up matey
Offline davemk4
« Reply #46 on: 13 June 2013, 06:29 »
Thanks
Depend on maf size :wink:  mine 70 so ordered  83mm - 70mm.
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline davemk4
« Reply #47 on: 13 June 2013, 06:31 »
Yer ill be foing something but unsure on what yet..... going to get the filter secured properltly with proper joiner then see what to go for
« Reply #48 on: 13 June 2013, 07:49 »
Thanks
I'm an idiot! Defo 70-86!
Offline Dalo Harkin
« Reply #49 on: 13 June 2013, 12:46 »
I was told 70-86 would be the ideal fit - mine will be here today  :tongue:
Want the weather to improve so I can give it a blast later after fitting  :evil:
