Author Topic: Jamex Coilovers ?  (Read 16571 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
Re: Jamex Coilovers ?
« Reply #20 on: 03 May 2010, 23:58 »
Quote
Nope on the threads, most of it should stay on when you clean them.
arrrrr i know what you mean :laugh:  on the threads were the ring is which goes up and down to adjust the ride high is.
:lipsrsealed: me got it now  :grin:
thanks so Waxoil is it? were can i pic some up ?
thanks
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
« Reply #21 on: 04 May 2010, 00:01 »
Quote
thanks
Halfords
Offline godsANGER
« Reply #22 on: 04 May 2010, 00:04 »
Nice , thanks guys
Just need for TinuxGTI to give me a review then purchasing time.  :cool:
Offline lemonadeX
« Reply #23 on: 04 May 2010, 00:20 »
Put these on my MkIV about a month ago - have done about 300 miles on them with no problems whatsoever. Firmer but not a harsh ride, exactly what I wanted.
Let me know if you have any questions.
Will
Offline godsANGER
« Reply #24 on: 04 May 2010, 00:35 »
Will
nice one will.
oks do you have adjustable drop links ? if so were did you get them from ?
Thanks
Offline lemonadeX
« Reply #25 on: 04 May 2010, 09:57 »
Will
nice one will.
Thanks
Nah I didn't go for adjustable DL's - I only lowered around 40mm and haven't had any rubbing issues at all. However I did replace the following parts, especially as some of the bolts have a nylon thread and aren't as good 2nd time around. Worth doing for the cost:
N 106 944 01 - Lower ARB Droplink to Wishbone Bolt - QTY 2 @ £0.96 ea
N 102 078 04 - Front Lower Strut Mounting Bolt - QTY 2 @ £1.72 ea
N 101 064 02 - Front Lower Strut Mounting Nut - QTY 2 @ £0.65 ea
1J0 412 331 C - Front Topmount - QTY 2 @ £9.10 ea
1J0 412 249 - Front Strut Bearing - QTY 2 @ £6.96 ea
N 905 173 04 - Rear Lower Strut Mounting Bolt - QTY 2 @ £1.08 ea
N 102 861 10 - Rear Lower Strut Mounting Nut - QTY 2 @ £0.44 ea
N 906 484 02 - Rear Upper Mounting Bolt - QTY 4 @ £1.51 ea
Will
Offline godsANGER
« Reply #26 on: 04 May 2010, 13:03 »
Will
nice one will.
Thanks
Will
Think i may as well replace myn as well, as there probably the ones which came with the car 10years ago lol
Need Topmounts anyways as my cheap ones i got have failed i think http://www.golfgtiforum.co.uk/index.php?topic=153530.0
Anything elce i may need ? so far its Coilovers-Droplinks-Waxoil- and all the above.
Offline lemonadeX
« Reply #27 on: 04 May 2010, 13:59 »
I covered all the threads in copper grease as well...big tub from Halfords costs about £7.
Will
Offline godsANGER
« Reply #28 on: 04 May 2010, 17:21 »
Waxoil, copper grease same thing ?
Offline rheady
« Reply #29 on: 04 May 2010, 17:47 »
No Wax oil is generally put on the underneath of a car to protect it. Copper grease is usually used to prevent threads sticking etc etc
