Author Topic: Fitting FK AK Street Coilovers to a MK4 Golf GTI 1.8T  (Read 11987 times)
Offline craig4004
  • I love MK4's, All about the ££££ Though :/
Just got a set of these:
 http://www.venommotorsport.com/manufacturer_product.php?manufacturer=FK&category=suspension&product=AKStreetCoilovers&make=VW&model=Golf%20Mk%204
Didnt come with any fitting instructions though :(...i know how to fit the fronts but am slightly confused about how the back ones go on. Does anyone know weather i need to take bits off my old rear shock absorbers and put them on the coilovers?
Thanks Craig
Offline Carley
Re: Fitting FK AK Street Coilovers to a MK4 Golf GTI 1.8T
« Reply #1 on: 13 August 2010, 09:52 »
If you don't get any help on here then try ringing Venom on 01254 820005 and see if they can help you.
Good luck.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #2 on: 13 August 2010, 09:59 »
the rears, you take your old shock off by undoing the 2 bolts at the strut top and 1 bolt the attaches the shock to the axle. Then when shock is off remove the top nut off the strut and take the dust guard and bumpstop off and put on your new shock, make sure you use the nut that is already on the new shock to hold the bumpstop and dust guide on the shock.
If you look in the maintenance section there is a full guide in there
Offline craig4004
« Reply #3 on: 13 August 2010, 10:01 »
Do you mean the maintaince section on here??
Offline Rhyso
« Reply #4 on: 13 August 2010, 10:03 »
That he does  :smiley:
Worth replacing all the bumpstops and top mounts whilst you got it all apart otherwise you'll be removing everything again in a few months  :sad:
Offline craig4004
« Reply #5 on: 13 August 2010, 10:08 »
sorry guys im a bit new to here, could someone send me the link to the page :) thanks
Offline Hulmie
Offline craig4004
« Reply #7 on: 13 August 2010, 12:20 »
thanks a lot guys :)
Offline Hulmie
« Reply #8 on: 13 August 2010, 12:25 »
no worries mate :afro:
