Author Topic: major prob with abs(fixed)  (Read 765 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 13 February 2009, 20:09 »
abs came on lst cleared with vagcom and went out in it today and it started to make 1 hell of a noise like the abs does when it kicks in.
so i pressed the brakes and it judds like the abs is kickin in and it was strugglein to stop.
any ideas
cud it b me senor that has gone didnt have time to check it will have to do that tomorrow.
« Last Edit: 14 February 2009, 18:45 by 18turbo »
Offline grahamster
Re: major prob with abs
« Reply #1 on: 13 February 2009, 20:38 »
My first guess is that a sensor ring on a hub may be at fault. I have seen this fault when a sensor ring cracks so the gaps are uneven this sends an uneven pulse signal to the abs ecu. I would also check that there isn't a loose sensor and there is no dirt or foreign objects on the sensor rings between the sensor.
these are just a couple of things that I have come accross. But it may well be something else. What foult codes were in the ABS?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #2 on: 14 February 2009, 01:30 »
what codes did you get on vagcom?
Offline (shakey)
Re: major prob with abs(fixed)
« Reply #3 on: 14 February 2009, 18:48 »
rite the problem was when i lowered it 2 wks ago i 4got to put the abs wire back on the strut.
so the wheel was rubbering on the wire and it cut throught it so just cut the wire and jioned them bk togather 4 now till i get some cion to buy a complete wire. :smiley:
Offline grahamster
« Reply #4 on: 14 February 2009, 19:17 »
nice one, glad you found the problem.  :smiley:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 14 February 2009, 19:52 »
problem solved  :rolleyes: :afro:
2000 Mkiv GTi 1.8T AGU
