Author Topic: Gttdi front brakes size?  (Read 603 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
« on: 27 January 2008, 13:09 »
Would any body know if the front discs on a gttdi 99 are the 288mm ones?
Need to get some?
Any body know a cheap online store?
 :sick:
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Offline Ridg
  • TDI - Soot Happens!
Re: Gttdi front brakes size?
« Reply #1 on: 27 January 2008, 13:29 »
which GT TDI?
as the 130 & 150 had 288mm standard but the 115 was smaller
personally i wouldn't put "cheap" discs or pads on mine as you never know when you'll need them.
i'd try www.gsfcarparts.com
you need to change the pads if you're changing the discs too
Offline herbster
« Reply #2 on: 27 January 2008, 21:51 »
Use your local motor factors, and the amount you save waiting and on postage could be put to cover the difference for green or red road spec pads, well worth the extra few pennies, if you do the discs too you would only need cross drilled to get the benefits, slots can be harsh on your pads. Take the wheel off and check the caliper you got before you order or get your bits, all the details will be on there, and measure the disc that will help alot too, shop around your factors though some are cheaper, i've used pcs, ces and romac in the derby area, all seem to be good stuff and all around the same prices.  :wink:
FAB is my life and the CABRIO's the wifes!!!!
