Author Topic: Catch can  (Read 5445 times)
Offline Dave_IOW
Re: Catch can
« Reply #20 on: 11 January 2011, 22:48 »
Also pretty sure you could remove the level bit and block the holes up if your that worried, or if it breaks..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline alexd
Re: Catch can
« Reply #21 on: 12 January 2011, 08:53 »
Toyosports one 9mm or 15mm, you choose for both?
Has level pipe on side of it, but heard good things about toyosports, think they do FMIC's too?
Toyosports CC
Yeah man, i got a full stainless off them for my old civic, quality was excellent, same as a japspeed system without the badge!
Offline 2001gti4
Re: Catch can
« Reply #22 on: 12 January 2011, 09:16 »
Use the search button, this has been posted about loads of times. I used an Ebay one with 15mm ports as did many others and none of us encountered any issues, it just depends if you want to pay more and have a namebrand catch can fitted....
My Golf is dead but at least I have this....
Offline rio_gti
Re: Catch can
« Reply #23 on: 12 January 2011, 09:22 »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=360335110423
just got this one, am waiting on the pipework to come thru thou to see how well it works
Offline ian007miles
Re: Catch can
« Reply #24 on: 12 January 2011, 13:38 »
right just ordered the one rio-gti said about and payed for next day delivery. now all i need is all the piping and joiners and for dave-iow to post up the pictures for me :grin:
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline rio_gti
Re: Catch can
« Reply #25 on: 12 January 2011, 15:32 »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230495679573&ssPageName=STRK:MEWNX:IT
if you contact the seller they will add other bits (such as a 19mm bend) for a few pounds more without a problem.  :smiley:
mine turned up this mornin and i've tried it on the can inlet/outlet - it is very loose so will need reducing.
have done it by slipping rubber pipe onto the inlet then the 19mm hose onto this making a tight fit.  :shocked:
Am i right in thinking that these pipes are not under pressure????   :undecided:
Offline 2001gti4
Re: Catch can
« Reply #26 on: 12 January 2011, 15:34 »
What you've done will be fine with a jubilee clip tightened up over the top....
Offline rio_gti
Re: Catch can
« Reply #27 on: 12 January 2011, 16:32 »
http://uk-mkivs.net/forums/t/269734.aspx
found this guide is this how everyone else has done it????
Offline ian007miles
Re: Catch can
« Reply #28 on: 12 January 2011, 18:07 »
Yer I see that one but it's not for the agu lol so I wanted one that explains exactly wot needs to be done on the agu thanx any way though
Offline Dave_IOW
Re: Catch can
« Reply #29 on: 12 January 2011, 18:19 »
Ill get you some pics Ian.
Hardest thing to do is get your oil resistant hose to bend in the right places to mount it..
It aint that flexible mate
