IMO stick with the 3bar, so far I have not seen any benfit froma 4bar reg ran with stock injectors. The 3bar and 4bar will scale under load to around 5.5 - 6bar, the 4bar will be richer down low which is not really needed as the gain best torque fuel you need a lambda of 13.4:1 which the 3bar can do fine.
At the top end the 3 and 4 bar are the same, a pump with a greater LPH with be a bigger benefit and allow for a richer cooler top end mix,
Nick
