Hi,
Got a 96MYR GTI eng code AGG which cuts out, tested through all the circuits and found it loses HT. No pattern hot or cold. hooked up a scope on the coil Green Red (eng ecu ign driver side) and then put channel two monitoring the ouput Green/Black wire from the crank pos sensor to eng ecu . Found the cps signal stays good when the engine cuts out(by that i mean the trace was a saw tooth pattern that elongated as the eng died ..it did NOT loose its shape and amplitude until the eng revs dropped to zero)... but the coil switching trace disappears causing HT to be lost (observed by a safe gap tool in-line with king lead from coil)..Voltmeter connected to both CPS and coil during monitoring confirmed there was no power +12v or gnd 0v supply faults to either unit during failure.
Basic inspection of ecu wiring and connections showed no wiring issues and it points toward an ign diver fault inside the eng ecu Simos Siemens Unit pt no 5WP4 256 VW no 037 906 025 R. Used the ELSAWIN CD to interogation i/o's to the ecu all ign +12volts and gnds good to ecu and coil. Took ecu pcb out to inspect for water ingress or signs of component burnt out , nothing showed visually.
Is there any other sensor that would cause the coil sw'n to fail during running apart from the cps ? the hall sensor in the dizzy tested ok (diagnostic section of elsawin cd mentioned its signal is only required on initial cranking by the ecu....disconnected the hall sensor 3-way plug whilst eng ran and it caused no change to the engine running at all.
Gonna send the ecu for bench testing,,has anyone had previous ecu related problems that have caused a similar fault ??
any help or advice would be much appreciated
Got some VAG-COM log files during cutting out if any on can help decipher them, PLEASE ADVISE ON HOW TO INSERT AN EXCEL FILE ???THANKS
regards
derrick
