Author Topic: Loose front end - semi cured.....or not  (Read 12376 times)
Offline Rhyso
« on: 30 March 2009, 21:00 »
over the last week or so the front end seems really loose and lacking feeback  :undecided:
the trip to the RR and Spring Fest ws interesting to say the least
it feels as if there's no resistance to the steering?  :huh:  i jacked the car up on Friday afternoon and poked and prodded everything but everything seems nice and tight and nothing was falling off
checked the power steering fluid and that seemed ok - it was on the Max mark on the little dipstick
think i've lost a wheel weight so will be getting the wheels re-balanced tomorrow but i'm after ideas and suggestions
tyre pressures are at 35 psi for the front and have been since i've had the wheels fitted last month
« Last Edit: 26 April 2009, 21:43 by Rhyso »
Offline richw911
Re: Loose front end
« Reply #1 on: 30 March 2009, 21:02 »
Try dropping the pressures  :undecided:
Worn bushes?
Offline Dubbz
Re: Loose front end
« Reply #2 on: 30 March 2009, 21:04 »
Ball joints?  :undecided:
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline Rhyso
Re: Loose front end
« Reply #3 on: 30 March 2009, 21:05 »
Worn bushes?
i'll try that but why would i suddenly feel it being loose?
think my wishbone bushes are worn and i've already planning to change them - need to finish the bathroom first  :grin: :grin:
also to throw something into the mix i had my discs and pads replaced last week but i still get a rumbling noise when i'm braking  :undecided:
Offline richw911
Re: Loose front end
« Reply #4 on: 30 March 2009, 21:09 »
Worn bushes?
Wishbones I think then.
Rear discs......
Offline Rhyso
Re: Loose front end
« Reply #5 on: 30 March 2009, 21:10 »
Worn bushes?
Rear discs......
i'll get those Ebay ones ordered then :afro:
noise is coming from the front  :undecided:
Offline bobbarley
  • I'm kind of a big deal...
Re: Loose front end
« Reply #6 on: 30 March 2009, 21:11 »
I'd go with wishbones too
Offline johnson6672
Re: Loose front end
« Reply #7 on: 30 March 2009, 21:12 »
Bearings, bushes, tire pressure seems high, unless your a taxi driver!
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline richw911
Re: Loose front end
« Reply #8 on: 30 March 2009, 21:14 »
Brake noise : Caliper fault? Bearing?  :undecided:
Let me know how you get on with the TT bushes bud  :wink:
Offline Rhyso
Re: Loose front end
« Reply #9 on: 30 March 2009, 21:15 »
pressures have been ok for the last 1200miles lol
will get it checked out tomorrow as cornering isn't a lot of fun at the moment  :sad:
Will let you know Rich - going to get them ordered tomorrow :afro:
