Golf mk4
Wazzzer
Turbo clutch pedal
Topic: Turbo clutch pedal (Read 1350 times)
zorg86
Turbo clutch pedal
01 October 2010, 19:23 »
Right guys second problem this week
Driving just clutch went very stiff and when I depressed pedal again it stuck to floor!
And won't come up but a White plastic thing were the ball off the pedal sits has come off could it just be this has snapped or the slave cylinder?
If it's the slave cylinder were are these located on the turbo agu engines?
Cheers in advance
andybod
GTI forum regular
Re: Turbo clutch pedal
01 October 2010, 21:07 »
pedals have been known to break so start having a look round there first i don't think there big money
zorg86
02 October 2010, 00:01 »
Pedals all seems fine? Why would the pedal go super stuff then after a few presses just hit the floor?
Does it not sound like a slave cylinder?
If so were are these located on the turbo golf?
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
02 October 2010, 00:11 »
you said a white plastic clip was found in the drivers foot well.
search on here for drop clutch pedal.
a clip on the back of the clutch pedal has broken hence the pedal on the floor. it is not the slave cylinder
MrRogers
Here all the time
02 October 2010, 02:19 »
Happend to me i had a very bad embarrassing incident in a tesco car park in the summer. Clutch just fell flat to the floor. Anywho i had to get a new pedal and the bits and pieces that came with it got my vw specialist to fit it all. A common fault apparently. Not much to fix at all. All in all i think i payed (wih labour) 60 odd quid. My thread:
http://www.golfgtiforum.co.uk/index.php?topic=155990.0
2000 Golf MK4 1.8 AGU black magic, Custom Code stage 1 remap, Forge 008, Simota Aeroform CAI, G60/VR6 Combo, Weitec GT Hicon coilovers, Golf GTI MK5 18" Monza style alloys, 10mm H&R spacers front + 20mm H&R spacers rear, OEM Polo MK5 aerial, Whiteline front ARB + Whiteline droplinks.
ggggolfgti
GTI forum regular
02 October 2010, 18:06 »
mine went couple of weeks ago £29 for parts from VW and 40mins to fix
249 bypass, ths fr3 engine mounts, S/S decat, 2.5'' straight through exhaust, induction kit, forge split r, coilovers, 18'' alloys, much more in the pipeline
houston
Reply #6 on:
03 October 2010, 21:15 »
it happened to me driving a relatives ibiza, a very common problem for them, and i assume they use the same pedals?
Golf mk4
Wazzzer
Turbo clutch pedal
