Praise where its due.
RED was in today for full front wheel alignment, Gaining acces to the ramp isnt an issue ( see piccy on link ) as its a sunken ramp so lowered cars are good to go.
Full laser kit, with a screen in the waiting area so you can see what your car should be and what it is, and the changes as they happen.
Even came to check if i wanted the negative camber taking off or did i want it set the same ( it was out of limits from one side to the other )
£35 for ya Toe adjust and addition costs if they do your camber. - Mine with LOADS of adjustment came to £55 - well worth it
Heres a Link,
http://www.merityre.co.uk/tyres-purley.htm - Easily worth a Trip from Oxford / Reading and surrounding Areas.
