Hi i have a mk 3 gti 8v on a R 97, its had a bit of a flat spot for a while but wasnt to bothered as just fitted a newman 268 fast road cam, lightened pulley and problem is still there , timing is correct, plugged it in to diagnostics came up Lambda sensor so i changed that still runs ruff from 2800ish rpm till about 4300rpm.
Also checked dizzy, rotor arm all usual bits.
If any one can help it would be much appricated.
